1996 Cadillac Deville Cold start problem
130,000 MILES • V8 • FWD • AUTOMATIC
BLFORSYTH
My caddy will not start right away when cold. After it warms up it starts just fine. Most all ignition and fuel system parts have been replaced already, any ideas? Thank you so much for your time.
Apr 9, 2010 at 1:25 PM
FACTORYJACK
  • 4,159 POSTS
Describe the condition when it won't start. Is it an extended crank, accompanied with a rough run and possibly some smoke from the tailpipe? Is it a Northstar or 4.9L? A couple of things to check would include a leaking fuel pressure regulator, there would be fuel in the vacuum line, and for consumption of coolant with no external sign. Another check would be fuel pressure at cold start, does it prime in 2 seconds, and is it adequate(45 psi)?
Apr 10, 2010 at 2:52 AM
BLFORSYTH
It is an extended cranking and then it stutters and starts and it is a Northstar engine. I am not sure about the smoke from the tailpipe.
Apr 10, 2010 at 3:26 AM
FACTORYJACK
  • 4,159 POSTS
I would lean towards the regulator, pull the vacuum line from the regulator itself, and check for liquid(raw) fuel. The other causes for extended crank would be fuel pressure, and possibly a missing cam sensor signal. The latter could bring a check engine light, but not necessarily.
Apr 10, 2010 at 5:32 PM
