1996 Cadillac Deville Brake Pad
59,000 MILES • V8 • FWD • AUTOMATIC
PRZYBYA
My right rear brake rotor has a peculiar wear pattern. The top of the rotor has a normal polished wear band from the pad, with another polished wear band at the bottom. Between them is a rust band indicating the center of the pad is not touching the rotor when the car is braked. It is almost as if the pad is warped in the middle and not contacting the rotor evenly across its surface.
Is this possible? What could the problem be? Does it require an entire brake job on the rear wheels?
I have never seen this in all my years working on cars.
Thanx.
Jun 3, 2008 at 6:24 AM
BUZZSAW
  • 1,198 POSTS
[quote:65be6b0d85="Przybya"]Brakes problem
1996 Cadillac Deville V8 Front Wheel Drive Automatic 59000 miles
Thanx.[/quote:65be6b0d85]
it happends, you can replace that rotor and sand the pads straight if enough pad is left
Jun 8, 2008 at 8:19 PM
