Wobbles when driving
1996 CADILLAC DEVILLE
115,000 MILES • V8 • FWD • AUTOMATIC
MLANG
I have a 96 Cadillac Seville with 115k miles. When I am driving down the road - not speed dependent - my car will feel like it is shifting right. Like the wind is blowing it except for it is not windy. If I hit a bump it feels like my backend wants to go in a different direction then my front. If I am driving down the road and turn the wheel slightly left my car responds like one of my tires are flat. If I turn slightly right the car feels normal like the tires are hugging the pavement. Sometime feels loose. What could be wrong.
Mar 11, 2008 at 4:09 AM
MLANG
[quote:fe6bde8e02="mlang"]Shakes or Wobbles problem
1996 Cadillac Deville V8 Front Wheel Drive Automatic 115000 miles
I have a 96 Cadillac Seville with 115k miles. When I am driving down the road - not speed dependent - my car will feel like it is shifting right. Like the wind is blowing it except for it is not windy. If I hit a bump it feels like my backend wants to go in a different direction then my front. If I am driving down the road and turn the wheel slightly left my car responds like one of my tires are flat. If I turn slightly right the car feels normal like the tires are hugging the pavement. Sometime feels loose. What could be wrong.[/quote:fe6bde8e02]
Mar 11, 2008 at 4:11 AM
CHISPAS
  • 20 POSTS
Make sure your wheels lug nuts are tight, also check your suspension components to see if something is loose or broken .
To be one the safe site avoid driving this car until you check or have someone check your car .
I know the Thech's in this forum will give you a more accurate and professional advise. Soon I hope.
Good luck.
Mar 11, 2008 at 5:42 AM
BUZZSAW
  • 1,198 POSTS
[quote:20fe6a08f7="Chispas"]Make sure your wheels lug nuts are tight, also check your suspension components to see if something is loose or broken .
Good luck.[/quote:20fe6a08f7]
the problem is the rear knuckles, the bushings are wore out, there about 400.00 bucks each plus labor to install them
Mar 13, 2008 at 5:59 PM
CHISPAS
  • 20 POSTS
WOW!!!
So how many knuckles are we talking about ?
And what is a" ball park" price the dealer is going to charge ?
Sounds like big problem .
Mar 14, 2008 at 9:07 AM
BUZZSAW
  • 1,198 POSTS
[quote:a00496cd2d="Chispas"]WOW!!!
Sounds like big problem .[/quote:a00496cd2d]
there are 2, prob 3-4 hrs and an alignment. you dont have to have it done at the dealer. to ck this you need to jack up a rear tire, grab it from side to side and up an down. does it move or feel loose?
if so I would buy the parts your self to prevent mark up of parts
Mar 14, 2008 at 9:55 AM
CHISPAS
  • 20 POSTS
Well...I guess if that is the problem a minimum of 1K. is going to be need it .
You have an interesting point., can you buy the parts and just have the shop installing then ?
Or they will feel offended and refuse to do the job.
I had some work done in the past were I know for a fact that the parts could not have cost as much as they charge me for it.
Buying the parts your self ....... excellent idea.
THANK YOU.
Mar 14, 2008 at 1:43 PM
BUZZSAW
  • 1,198 POSTS
[quote:cf84bc5a95="Chispas"]Well...I guess if that is the problem a minimum of 1K. is going to be need it .
THANK YOU.[/quote:cf84bc5a95]
well that means they dont have to go get them for 1.. Places charge more for parts where they have to go and get them, gas and all. I believe these parts are dealer only ( for the knuckles) check them first before you buy them.
first of all you need a good place for someone to work on your car. find a place where the mechanics dont make flat rate hour. They are less ampt to rip you off
Mar 15, 2008 at 7:39 PM
CHISPAS
  • 20 POSTS
How you know if the shop pay there mechanics by the hour .
Do they post this info or you have to ask ?
Mar 16, 2008 at 6:15 AM
BUZZSAW
  • 1,198 POSTS
[quote:e5022efea3="Chispas"]How you know if the shop pay there mechanics by the hour .
Thank you.[/quote:e5022efea3]
just ask. call around. there hard to find
Mar 16, 2008 at 11:05 AM
JAKESTER55
  • 6 POSTS
What you and a great many other Cadillac owners are feeling is not bad shocks, alignment or tires. It's rear knuckle Bushings. The swaying and wobble in the back is due to the upper bushings allowing the camber of the wheel to jump around and acts like a low tire..... FIX YOUR PROBLEM WITH US:
Cadillac Rear Knuckle Bushing Replacement ! They are Automotive Grade OE Parts ... don't accept less !!
Don't replace the entire knuckle when you can just replace the bushing !
$199.00 +shipping does both sides upper and lower. Or buy just the Upper Bushings for $ 119.00 +shipping !
Last Shot Auto Parts LLC
https://www.2carpros.com/forum/automotive_pictures/249306_9fa1_2_2.jpg
Dec 5, 2008 at 9:11 AM
