1994 Cadillac Deville Vibration in rear at 60 mph
118,000 MILES • V8 • 2WD • AUTOMATIC
MACGYV3R
I have a bad vibration in the rear when going 60 mph or higher. What problem do I have with the rear end of my vehicle if my tires are balanced. It is causing wear on outer part of rear tire on left side.
Jun 16, 2009 at 2:13 PM
FACTORYJACK
  • 4,159 POSTS
Worn knuckle bushings, bent wheel, separated tire, loose rear tie rod. Have the suspension inspected, and assessed.
Jun 16, 2009 at 4:25 PM
MACGYV3R
Thanks!
Jun 17, 2009 at 9:34 AM
