1996 Cadillac Deville
101,000 MILES • V8 • FWD • AUTOMATIC
RICHARD DIMATTEO
where are the ground connections on a 96 caddy deville. veh was reciently repaired. comp module was removed to inspect. problem was ground from battery. veh runs but info states: anti-theft problem veh may not start. some info does not register on info screen. gearshift info (prn321) flashes constantly. since ran new grounds, believe origional ground has to be connected to fix problem, but where. HELP
Dec 24, 2007 at 1:50 AM
BUZZSAW
  • 1,198 POSTS
[quote:73745f0acb="Richard DiMatteo"]Electrical problem
1996 Cadillac Deville V8 Front Wheel Drive Automatic 101000 miles
where are the ground connections on a 96 caddy deville. veh was reciently repaired. comp module was removed to inspect. problem was ground from battery. veh runs but info states: anti-theft problem veh may not start. some info does not register on info screen. gearshift info (prn321) flashes constantly. since ran new grounds, believe origional ground has to be connected to fix problem, but where. HELP[/quote:73745f0acb]
needs to have the PCM relearned, theft sys active, doesnt reconize the key
Dec 28, 2007 at 7:08 AM
