1996 Cadillac Deville
OSEA
Suspension problem
1996 Cadillac Deville V8 133133 miles
i have a rs0038 msg current but srvc ride control msg went away any one know what to do to fix this i checked fuse in rear was ok thanks for all help
Jan 23, 2008 at 3:05 AM
BUZZSAW
  • 1,198 POSTS
[quote:af9fa9897c="osea"]Suspension problem
i have a rs0038 msg current but srvc ride control msg went away any one know what to do to fix this i checked fuse in rear was ok thanks for all help[/quote:af9fa9897c]
does the rear shocks fully extend? does it seam to ride level? I belive you have a wire broken or corroded real bad to the compressors exhaust for the shocks or a compressor going bad, its usually the wire, you will have to ck them from the ride sensor to the compressor, I belive there are 4 wires
Jan 25, 2008 at 8:10 AM
