1996 Cadillac Deville
SIRPAUL
Whats the clicking noise coming from the front passenger wheel well'
cv joint or bearing? It only starts after about 10 min. of driving.
Jul 12, 2008 at 9:20 PM
MMPRINCE4000
  • 8,548 POSTS
Generally CV joints will make more noise when turning, while bad bearings will do it all the time.
Inspect the inner and outer CV boots for lubricant leakage. If you find any, replace the CV axle.
Raise the car and put on jackstands, grasp wheel and see if there is any lateral or vertical movement, if so, it would be a bearing, ball joint, tie rod or bushing.
Jul 12, 2008 at 11:48 PM
