Is the engine cranking, or does the starter just whine? If it doesnt crank, the starter may have been ruined. Also remove the distributor cap if it does crank, check for moisture, wipe out with paper towel, let it dry out, then try it, you can also spray the wires with WD-40 this will dry them out.
SPONSORED LINKS
Thursday, February 21st, 2008 AT 7:35 AM
