1995 Cadillac Deville tractoin controll
110,000 MILES • V8 • FWD • AUTOMATIC
MPHANCOCK
after the first time of pumping brakes the anti-brake light comes on and then the traction control starts to flash in the info. center. although i have great brakes when stopping. had brakes front and back inspecked the shop said they look new. how can i fix the problem? the car is 95 cad. deville 4.9 engine.
Feb 9, 2010 at 11:42 AM
FACTORYJACK
  • 4,159 POSTS
Verify that the brake fluid level is adequate to not set a low fluid concern when the brake is pressed. Then you could press off and warmer on your climate panel to enter diagnostics, record and report the ABS codes.
Feb 9, 2010 at 3:09 PM
