1995 Cadillac Deville Stop engine low oil pressure
BBROWNBS
  • 1995 CADILLAC DEVILLE
  • V8
  • FWD
  • 182,000 MILES
Stop Engine or low oil pressure appears in display. Changed oil and message appears when engine is idling, Checked oil and level is OK. Is computer going bad? If so, can I replace it myself.
Monday, December 1st, 2008 AT 9:23 PM
DOCFIXIT
  • 18,828 POSTS
Before you replace ECM need to verify oil pressure. Need to hook up a manual type oil gague if pressure is good then try oil sender first. If pres low need to rebuild or drive till it blows.
Tuesday, December 2nd, 2008 AT 8:29 AM
