1995 Cadillac Deville stallingout when driving
245,000 MILES • V8 • 2WD • AUTOMATIC
MICHAELHATCH
why is the car stallingout when driving
May 30, 2010 at 1:29 PM
  • 75,988 POSTS
Next time it stalls out immediately do below to determine if its fuel or spark problem do not wait for nothing
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 30, 2010 at 1:43 PM
