1995 Cadillac Deville routing serpentine drive belt
175,000 MILES • V8 • 2WD • AUTOMATIC
ODIGGIDY
need a diagram of proceedure
Jan 20, 2008 at 5:36 AM
FISHERMAN
  • 937 POSTS
Hello !! here you have the route of the belt diagram and the tensioner range. Engines with serpentine belts have automatic tensioner. If tension is not as specified, check belt operating length and tensioner operating range. Replace belt or tensioner as necessary. to replace the belt just release the tension on the tensioner remove the old belt and install the new-one. thanks a lot for your donation !!
https://images.2carpros.com/forum/automotive_pictures/576_cadillac_deville_95_1.jpg
https://images.2carpros.com/forum/automotive_pictures/576_cadillac_deville_951_1.jpg
Good Luck !!
Jan 20, 2008 at 6:10 AM
