1995 Cadillac Deville over heating
94,000 MILES • V8 • FWD • AUTOMATIC
BRANDONG1234
my car keeps over heating i replaced the thermastat\
flushed the radiator its not leaking and the water is circulating
May 9, 2008 at 3:42 PM
  • 75,988 POSTS
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
May 9, 2008 at 3:54 PM
