1995 Cadillac Deville leaking fluid
CADIOLAC
Steering problem
1995 Cadillac Deville V8 Front Wheel Drive 140000 miles
how do i find and fix a power steering fluid leak, the pump is not leaking. resevoir is seperate from pump.
Jul 22, 2010 at 9:27 AM
  • 31,937 POSTS
Hi there,
If the pump is ok, it will be the rack / steering box, or the high or low pressure hose, if you can get the car on a hoist or jack it up with sturdy stands, you should be able to wash it down and run the engine, turning the steering slowly you should see the fresh leak forming.
mark (mhpautos)
Jul 22, 2010 at 10:32 AM
