1995 Cadillac Deville Interiror courtesy lights
TONY KEAR
  • 1995 CADILLAC DEVILLE
Electrical problem
1995 Cadillac Deville V8 Front Wheel Drive 140000 miles
My interiror courtesy lights keep turning on and I am unable to turn them off. I had to take the fuse otu to keep them off. The "trunk open" appears on dash when the fuse is out.
Sunday, January 4th, 2009 AT 10:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It sounds like one of your door ajar switches is sticking or is faulty. This will cause the interior lights to illuminate as if you were opening the car door(s). Spray some WD40 in all door jambs and see if this temporarily fixes the issue.
Hope this helps.
Thanks for using 2carpros. Com!
Sunday, January 4th, 2009 AT 11:06 PM
TONY KEAR
Say I tried something different with my courtesy light problem. I am using the other remote entry module.
(keyless entry). I put the fuse back in a little while ago and the lights haven't come on yet. I'm thinking the other module might have been turning the lights on. I took the battery out of it. Comments?
Tuesday, January 6th, 2009 AT 9:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
That is possible. Something may have shorted out inside the key fob unit. Just keep an eye on the lights for a few days and if they stay out, trade the key fobs back out to see if they come back on. If they do come back on then you got if figured out already ;)
Wednesday, January 7th, 2009 AT 12:35 AM
