my engine light comes on and off and had it diagnosed and it said keep memory alive needs to be reset. what does this mean and hoe do u reset it.
Apr 3, 2009 at 9:38 AM
FACTORYJACK
✓Experienced Mechanic
The keep alive reset code should not turn your check engine light on, this code occurs after battery disconnect. You should have had another code in the system.
