1995 Cadillac Deville dislodged caliper pivot joint
CADILLACPIMPINMD
Brakes problem
1995 Cadillac Deville V8 Wheel Drive Type unknown Automatic 163000 miles
some way some how the pivot joint on my caliper has become unscrewed and now my caliper is in 2 parts. I need to try and screw it back on some how and I'm wondering if theres some method or trick I should know since theres no bolt end i can work with? any help would be greatly appreciated...
Mar 18, 2008 at 5:57 AM
BUZZSAW
  • 1,198 POSTS
[quote:98001fb0df="cadillacpimpinmd"]Brakes problem
some way some how the pivot joint on my caliper has become unscrewed and now my caliper is in 2 parts. I need to try and screw it back on some how and I'm wondering if theres some method or trick I should know since theres no bolt end i can work with? any help would be greatly appreciated...[/quote:98001fb0df]
I believe they are pressed in, you need new ones. go to a junk yard, or a dealer
Mar 18, 2008 at 6:16 AM
