1995 Cadillac Deville V8 Front Wheel Drive 140000 miles
This winter,no heat, ,hot water to and frome heater core,fan runs, replaced vacume lines,checked fuses yet very little air coming frome vents.Everything fine when switched to cooling then ,about a week ago same thing happened to cooling mode,charge ok ,fuses compressor,fan,everything appears ok except very little air coming frome vents can you help? Hopefully with your help I can fix it muself,I havf to,68,living on SS 'Tom'
Jun 17, 2009 at 7:03 AM
