How do I change the rear Brake pads? Specifically, get the rear stablizing bar out of the way?
Jul 18, 2009 at 3:58 AM
FACTORYJACK
✓Experienced Mechanic
You don't take the bar out. To just change the pads, remove the bottom caliper bolt(12mm), and the park brake cable bracket bolt(14mm). Rotate the caliper up on the slide pin, and the pads can be removed and replaced. You will need to turn the piston in to recover the clearance for the new pads.
Jul 19, 2009 at 8:57 AM
BOB GEISLER
MEMBER
Must jack the car up. Place blocks under the main spring and let the jack down so that the car's weight is on the spring and that action rotates the stablizing bar down and out of the way of the emergency brake arm which is connected to the caliper. Then I am able to fully rotate the caliper up, so that the old pads can be removed.
Jul 20, 2009 at 1:08 AM
FACTORYJACK
Sounds like you got it whipped. I usually perform the service on a hoist that lifts the body, and the suspension hangs.
