1994 Cadillac Deville Won't start
TIM QUIST
1994 Cadillac Deville V8 Front Wheel Drive Automatic
I recently started my car to get it in the drive way so I could get it ready to sell. After cleaing for about 1/2 hour I found it would not start again. I pulled the battery and had it checked and it was fine. Pulled the starter and had it checked and it tested good. Still wont start?
Aug 14, 2010 at 5:12 AM
FACTORYJACK
  • 4,159 POSTS
Is there any messages? HAve you checked the signal at the starter? It could be a faulty or misadjusted park/neutral switch. It could even be a fault with the vehicle theft system, most often the wires break at the ignition cylinder, that are responsible for transmitting the key pellet value to the VATS module. Try starting with the shifter in neutral, inspect the key pellet, if it is worn flat try another key.
Aug 15, 2010 at 9:30 AM
TIM QUIST
No messages. Tried two dfferent keys. Key pads not flat. Neither worked in Park or Neutral. When I turn key the dash lights all go out and I hear a quick buzz sound some where around the area of the radio. How can I check the ignition wire?
Aug 15, 2010 at 11:33 AM
FACTORYJACK
  • 4,159 POSTS
If it is a northstar powertrain, there is a large purple wire that goes to a connector at the front of the rear bank of cylinders. This wire is you start signal wire. If you disconnect it and check the harness side with a test light, in the start position it will light if a signal is being sent. You can also power the starter side of it and that would engage the starter. In key on, if you power the starter and it starts and runs, you have a problem with the start circuit.
If it is a 4.9, the signal is the small stud at the starter. You can check it with a test light as well.
Aug 16, 2010 at 6:02 PM
