1994 Cadillac Deville transmission sound
1994 CADILLAC DEVILLE
110,420 MILES • V8 • 2WD • AUTOMATIC
BAD123
I had my Cadillac transmission fixed and when i got it back it slightly jerked when slowing down in upper gears. now when driving when i slow down in second or third gear it starts to make a real low rumble or rrr sound .When i checked the fluid before it seemed o.k. but now it is all over the bottom of the dip stick and bubbles are on it what is wrong.
May 26, 2008 at 5:07 PM
BUZZSAW
  • 1,198 POSTS
[quote:2420c27440="bad123"]Transmission problem
1994 Cadillac Deville V8 Two Wheel Drive Automatic 110420 miles
I had my cadillacs transmission fixed and when i got it back it slightly jerked when slowing down in upper gears. now when driving when i slow down in second or third gear it starts to make a real low rumble or rrrrrrrrrr sound .When i checked the fluid before it seemed o.k. but now it is all over the bottom of the dip stick and bubbles are on it what is wrong.[/quote:2420c27440]
what did you have fixed?
May 26, 2008 at 7:33 PM
BAD123
They replaced the tcc solenoid & torque converter.
May 27, 2008 at 11:04 AM
