1994 Cadillac Deville Thumping Sound & Catch In Steerin
1994 CADILLAC DEVILLE
129,000 MILES • V8 • FWD • AUTOMATIC
DAVEOF88
I have a 1994 Cadillac Deville; awesome car. One problem - when I turn it to the left, it makes a slight thump sound and I feel like a catch for a brief moment. After getting past that point (which I haven't had a problem doing, so far), it steers and sounds normally.
When turning back to the right, it's non-existent. It only does it once you start turning to the left. For example: after turning right, once you begin to turn the wheel back to the left, it happens. Doesn't matter if you're recovering from a turn or simply keeping it in the road. It only happens when you begin to turn to the left.
Please help, I don't trust driving it in this condition - at least until I understand more about the issue. Thanks!
Aug 31, 2010 at 11:16 PM
FACTORYJACK
  • 4,159 POSTS
Something may be loose or worn in the front end, or possibly a steering gear mounting problem, like a loose/missing bolt or broken mount. Can you duplicate it when stationary and turning back and forth, you may be able to locate it with aid of a second person.
Sep 2, 2010 at 1:45 PM
