1994 Cadillac Deville reverse
184,673 MILES • V8 • FWD • AUTOMATIC
ATOWN806
  • 9 POSTS
i have a 1994 cadillac sedan deville the car runs and drives great but my problem is reverse can only be engaged by pressing the accelerator down to get it to move i have changed the fluid and filter and added lucas trans treatmeant the old fluid wasnt burnt and there wasnt that nuch metal in the pan any info will be greatly appreciated
Mar 22, 2008 at 5:34 PM
BUZZSAW
  • 1,198 POSTS
[quote:719c29ba46="atown806"]Transmission problem
1994 Cadillac Deville V8 Front Wheel Drive Automatic 184673 miles
i have a 1994 cadillac sedan deville the car runs and drives great but my problem is reverse can only be engaged by pressing the accelerator down to get it to move i have changed the fluid and filter and added lucas trans treatmeant the old fluid wasnt burnt and there wasnt that nuch metal in the pan any info will be greatly appreciated[/quote:719c29ba46]
were there any chuncks of metal in the pan?
Mar 24, 2008 at 4:32 AM
ATOWN806
  • 9 POSTS
no there wasnt any chunks of metal there was hardly any metal my dad said it looked normal when you first start it reverse works pretty good but when it warms up you have to gas it a couple of times but when it starts to catch it goes good thank you for your information sir :)
Mar 25, 2008 at 5:14 PM
BUZZSAW
  • 1,198 POSTS
[quote:611ce4bed4="atown806"]no there wasnt any chunks of metal there was hardly any metal my dad said it looked normal when you first start it reverse works pretty good but when it warms up you have to gas it a couple of times but when it starts to catch it goes good thank you for your information sir :)[/quote:611ce4bed4]
if there were bronze shavings in there thats bad, gray debris on the magnet is normal
the filters for the trans are in the side pan, the only way to replace them is to remove the trans you just replaced screens that are cleanable if you didnt
Mar 26, 2008 at 11:54 AM
