1994 Cadillac Deville erractic behavior
109,000 MILES • V8 • FWD • AUTOMATIC
MYPOSSE
i have a 94 cad. deville 4.9
i had the isc motor and tps replaced due to loosing power on freeway and at stops engine starts vibrating and starts to ping and gasping for fuel then it stops and then it runs fine.
Jun 8, 2008 at 9:58 AM
BUZZSAW
  • 1,198 POSTS
[quote:4c29b96e63="myposse"]Engine Performance problem
1994 Cadillac Deville V8 Front Wheel Drive Automatic 109000 miles
i had the isc motor and tps replaced due to loosing power on freeway and at stops engine starts vibrating and starts to ping and gasping for fuel then it stops and then it runs fine.[/quote:4c29b96e63]
are you sure about the motor size? it should be a 4.6 northstar, 4.9 was in the 93's
Scan your codes for me, off and warmer on the heater controls at the same time, with your key in the on position
Jun 8, 2008 at 7:12 PM
MYPOSSE
i'm sure of the engine size and year. and theres no codes. i tried them all. thanks for for your response.
Jun 9, 2008 at 8:53 AM
