caliper change?
104,000 MILES • V8 • 2WD • AUTOMATIC
SCOTTIEBBC10169
how in the heck do i take off the caliper to change brake pads??? how to remove slip cover bolt or whatever it is??? thanks
Feb 22, 2010 at 9:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Here is a guide to show you how to replace the front brake pads and a diagrams to help you see what it will be like on your car.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Cheers
Feb 22, 2010 at 2:54 PM
WAKESK888
  • 21 POSTS
I am trying to replace a couple wheel studs on my front right wheel an am not understanding how to get the calipers off so i can get to the studs. What is the easys way to replace the front wheel studs?
Jul 31, 2018 at 7:00 AM (Merged)
LEGITIMATE007
  • 5,121 POSTS
your calipers should have two torx bit bolts on the inside of the caliper. once you get those off , then you will remove the rotor and get a press or c clamp and press the studs out of the plate.
WAKESK888
  • 21 POSTS
[quote:71f50aa3f7="legitimate007"]your calipers should have two torx bit bolts on the inside of the caliper. once you get those off , then you will remove the rotor and get a press or c clamp and press the studs out of the plate.[/quote:71f50aa3f7]
I am in the middle of trying to get the caliper off now. I do not have a Torque wrench so is there any other tool that i could use to get the torque bolts out with like an allen key or something. An if so what size are the bolts ?
BUZZSAW
  • 1,198 POSTS
[quote:d414fb1624="wakesk888"][quote:d414fb1624="legitimate007"]your calipers should have two torx bit bolts on the inside of the caliper. once you get those off , then you will remove the rotor and get a press or c clamp and press the studs out of the plate.[/quote:d414fb1624]
I am in the middle of trying to get the caliper off now. I do not have a Torque wrench so is there any other tool that i could use to get the torque bolts out with like an allen key or something. An if so what size are the bolts ?[/quote:d414fb1624]
its a 3/8th in hex nut or allen wrench, to get the studs out hit them with a hammer, to get them back in use two of you lug nuts to do it
WAKESK888
  • 21 POSTS
What kind of tool besides a torque wrench would i use to remove the two torque bolts from m front calipers so I can get to my replacing my wheel studs? Alos what side bolts are in there because i can't find anything to fit them?
Jul 31, 2018 at 7:01 AM (Merged)
BUZZSAW
  • 1,198 POSTS
[quote:ef0342c914="wakesk888"]Brakes problem
1992 Cadillac Deville V8 Front Wheel Drive Automatic 138000 miles
What kind of tool besides a torque wrench would i use to remove the two torque bolts from m front calipers so I can get to my replacing my wheel studs? Alos what side bolts are in there because i can't find anything to fit them?[/quote:ef0342c914]
its a 3/8 in hex nut not a torx, and a wrachet
