1994 Cadillac Deville Back Brakes wont work
130,000 MILES • V8 • FWD • AUTOMATIC
94_CADI
Couple days ago I went and changed all the pads on my 94 cadi sedan deville after I got done I went to bleed the brakes and the front ones were working just fine but the back ones are not geting no fluid so I went and put a new master cylinder in there but still the same front ones work but the back ones get no fluid what so ever, yes it has abs and its disc brakes all the way around. Please help
Jul 15, 2009 at 3:52 PM
FACTORYJACK
  • 4,159 POSTS
Have you taken out the bleeder screws and seen if they are plugged? If there was no rubber caps on them, it is a good chance they are. Did you bench bleed the master cylinder, also? You could have a lot of air in the system. What was the pedal like before you replaced the master cylinder?
Jul 16, 2009 at 4:20 PM
94_CADI
umm i figured it out its the valves
Jul 18, 2009 at 1:05 PM
