1993 Cadillac Deville water pump replace
100,000 MILES • V8 • 2WD • AUTOMATIC
DOUGWERNER
do you go after a water pump replacement on a cadillac sedan deville 4.8 through the tire well
Dec 31, 2009 at 9:39 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation!
You will need to remove the air filter assembly and remove the coolant recovery tank. Then remove the cross brace. This gives access to the water pump pulley and bolts.
Dec 31, 2009 at 9:48 AM
