Do you go after a water pump replacement on a cadillac sedan deville 4.8 through the tire well
Thursday, December 31st, 2009 AT 5:39 PM
BLUELIGHTNIN6
MECHANIC
Hello and thanks for the donation!
You will need to remove the air filter assembly and remove the coolant recovery tank. Then remove the cross brace. This gives access to the water pump pulley and bolts.
