1993 Cadillac Deville Starting problems
60,000 MILES • V8 • FWD • AUTOMATIC
COLLEGEINHAWAII
I have replaced the starter but the car still wont start. is there something else to check?
Feb 12, 2010 at 9:00 AM
FACTORYJACK
  • 4,159 POSTS
Assuming the symptom is no crank? It could be theft system related, what does the security telltale do? You can short the start signal stud to the battery stud on the starter, if it starts and runs(with key on) then it is a start circuit or theft issue.
Feb 12, 2010 at 3:30 PM
CHUPACHAM
[quote:d7ddd3307b="collegeinhawaii"]Engine Mechanical problem
1993 Cadillac Deville V8 Front Wheel Drive Automatic 60000 miles
I have replaced the starter but the car still wont start. is there something else to check?[/quote:d7ddd3307b]
if your problem is that the car doesn't crank
you might want to check your nuetral safety switch.
Feb 13, 2010 at 5:04 AM
