I have replaced the starter but the car still wont start. Is there something else to check?
Friday, February 12th, 2010 AT 5:00 PM
FACTORYJACK
MECHANIC
Assuming the symptom is no crank? It could be theft system related, what does the security telltale do? You can short the start signal stud to the battery stud on the starter, if it starts and runs(with key on) then it is a start circuit or theft issue.
SPONSORED LINKS
Friday, February 12th, 2010 AT 11:30 PM
CHUPACHAM
MEMBER
If your problem is that the car doesn't crank
you might want to check your nuetral safety switch.
