1993 Cadillac Deville Starting Problem
159,000 MILES • V8 • FWD • AUTOMATIC
TPERDUE
Car will not start with ignition key at times; acts like the battery is disconnected. I've replaced the starter and solinoid but problem persists. When the car won't start, I have to wait a few hours then it will start. To avoid this long wait, I put a wire from where the ignition wire hooks to the solinoid. When I touch the hot side of the battery with this wire, it will start everytime. It is real bad to start when it is hot weather here in Alabama. This is when I had to wait several hours to start car with the ignition key before installing hot wire. I've had the ignition chip keys checked by Cadillac dealers; they are good.
When the car won't start with the ignition key, it acts like there is no power from the ignition switch to the starter solinoid.
Please give me an idea of what the problem is. It has myself and many mechanics baffled. I've been starting the car with the wire for 8 years. Any help would be appreciated.
May 24, 2010 at 2:40 PM
  • 75,988 POSTS
Check and test the ignition switch and park and neutral switch
May 24, 2010 at 3:13 PM
TPERDUE
[quote:e705581459="rasmataz"]Check and test the ignition switch and park and neutral switch[/quote:e705581459]
How do you check the ignition switch without taking it out? I had already checked the park and neutral switch.
Thanks so much for your prompt reply.
May 30, 2010 at 9:35 AM
