1993 Cadillac Deville Ignition Switch problem i believe
14,500 MILES • V8 • FWD • AUTOMATIC
JBOB13
About 2 months ago, my brother was hooking up a cd player for me. He has always done a good job before. We were testing the cd player with the ignition turned on. Everything was working fine with the cd player, until i noticed my windows werent rolling up or down for me. Next thing i know, my ignition was basically spinning around when turning the key back and forth. The car then was not cranking like before. Also the car will not go into any gear at all. Even with the ignition turned to Accessory. Also my trunk(motorized), is not closing. All these problems happend at once. During the cd player installation. All these problems somehow caused the car to drain my battery completely down. I will never buy another Cadillac after this. Please let me know what i need to do to get this fixed. Im losing money because of this situation. Also, can u let me know where to locate the transmission linkage, so i can possibly place the car in gear so i can take it to the local shop here. Thank you very much for any info. you have for me.
Sep 27, 2010 at 7:09 AM
CADIEMAN
  • 3,544 POSTS
ok you have to charge the battery on ten amps. all
day long. clear any codes. ill montior this post
Sep 29, 2010 at 8:32 AM
