1993 Cadillac Deville HOOD WILL NOT OPEN
99,000 MILES • V8 • 2WD • AUTOMATIC
TOMMYO
I CAN'T OPEN THE HOOD. I PULLED LEVER DOES NOT WORK ANY MORE, I USED PLIERS TO PULL CABLE WORK FOR A WHILE. DOES NOT WORK ANY MORE. I HAD HELP WHILE PULLING CABLE ,MY HELP WOULD PULL AND BANG ON HOOD BUT WILL NOT BULGE.ANY SOLUTION?
Mar 14, 2008 at 2:50 AM
BLACKOP555
  • 10,386 POSTS
your best bet is to try to use a screwdriver to pop the hood open then replace the cable and mechanism it is probably broken from the force of using the pliers.
Mar 14, 2008 at 5:29 AM
