1993 Cadillac Deville car is stalling at idle and bucking w
EJBYARS
  • 1993 CADILLAC DEVILLE
  • V8
  • FWD
  • 280,000 MILES
June 9 on my way out to work my car started to lose power as I was driving along and acting like it was going to stall so I turned around and started back home. Then it seemed to clear up so I left again and after driving about 10 miles it started again, losing power even with my foot on the gas and then going on but I kept driving trying to get it to the shop. When I was waiting behind traffic I saw some smoke and pulled off the road and called for a tow. They put on a distributor, a coil, repaired the electrical problem (the smoke) and put on a new muffler. When I got the car back it had started stalling at idle and seemed to be running rough but the gas mileage was good and no idiot lights were on so seemed ok. Then the 'service engine soon' light came on and I took it back to the mechanic but other than replacing a $2.00 valve that looked worn they couldn't find anything and said there were no computer codes. So, Friday on my way home it started the losing power thing again but not as bad as the first time and I made it home. The mechanic is on his way to tow it to the shop and test the fuel pump. What do you think? It is a 1993 Cadillac Sedan Deville with 280,000 miles that rides and drives, normally, like a dream and I love the car.
Monday, July 27th, 2009 AT 9:00 AM
FACTORYJACK
  • 4,159 POSTS
A failing fuel pump could be a cause.
Monday, July 27th, 2009 AT 10:44 PM
EJBYARS
  • 5 POSTS
My car iis back to (well not exactly like the original but close enough)normal. They replaced the fuel pump. It still doesn't run as smoothly as it originally did but I guess it is like when you have to replace a door at your home - it is never the same as the original.
Wednesday, July 29th, 2009 AT 1:35 PM
EJBYARS
  • 5 POSTS
Update - after they put the fuel pump on it ran better but still stalled and ran rough so I finally took it back to the shop Tuesday August 25. They finally saw that it needed a new idler arm motor. It was not moving at all. This is probably all it needed from the start but I don't know. I'm going to get the car now and will update if it is in fact fixed.
Friday, August 28th, 2009 AT 12:10 PM
