1993 Cadillac Deville
1991MX6
  • 1993 CADILLAC DEVILLE
  • V8
  • FWD
  • 140,000 MILES
Irregular idle. It revs itself from idle to 2000 rpm, up and down.
Saturday, May 23rd, 2009 AT 7:27 PM
Clean out the idle air control valve, EGR and PCV valves and see what happens-might also want to check fuel pressue.
Saturday, May 23rd, 2009 AT 7:29 PM
1991MX6
I just replaced the PCV and fuel pump. You think the EGR is the culprit?Im sure its old. THANK YOU for your time and knowledge. Its sincerely appreciated.
Saturday, May 23rd, 2009 AT 7:52 PM
Did you cleaned out the IACV if not clean it along with the EGR valve and see what happens.
Saturday, May 23rd, 2009 AT 11:16 PM
FACTORYJACK
  • 4,159 POSTS
It does not have an IAC valve, It is ISC motor with nose switch that senses throttle at idle. You might try cleaning the engine ground, and performing a minimum idle/tp adjustment and idle learn.
Sunday, May 24th, 2009 AT 12:03 PM
