1992 Cadillac Deville trunk mechanism
155,011 MILES • V8 • FWD • AUTOMATIC
MOLDER1012
my trunk will not close all of the way. it will latch but will not close all of the way. is there a way to reset it or restart the motor?
Aug 30, 2010 at 3:05 PM
FACTORYJACK
  • 4,159 POSTS
Highest probability of the fault is the pull down switch that is on the actuator, not the latch. You can try rapping on the actuato with a screwdriver handle or equivalent, to see if you can get some operation out of it. The switch itself may be discontinued as a new part, so you may have trouble locating a new one.
Aug 31, 2010 at 6:14 PM
