1992 Cadillac Deville starting
13,000 MILES • V8 • 2WD • AUTOMATIC
GMWILLIS
The car does not start sometimes but does have power. If you wait 5-10 minutes and try again it will start. The starter has been changed but the problem persists and seems to be getting worse. It used to happen every week or so now it is every couple of days.
Feb 19, 2010 at 2:10 PM
  • 75,988 POSTS
Do below to determine whether it's fuel or spark problem:
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 19, 2010 at 8:46 PM
