1992 Cadillac Deville radiator
12,000 MILES • V8 • FWD • MANUAL
TERRYM1955
Changed radiator(plastic hose barb blew) and have no heat now (was fine prior to change). also the coolant flow is not good
Dec 17, 2008 at 4:08 AM
DOCFIXIT
  • 18,828 POSTS
May have air lock see if you can find bleed valve or jack up front and run till air is removed.
Dec 17, 2008 at 6:04 AM
