1992 Cadillac Deville push button starter
MARCOHILL
Electrical problem
1992 Cadillac Deville 6 cyl Front Wheel Drive Automatic
i have a 92 deville that won't start, i've replaced the battery, starter, and ignition starter switch. when i turn the key all the way i get nothing, though if i cross terminals on the starter she starts right up. i was told it could be the nuetral safety switch or the security system both are costly. so i was wondering if i install a simple push button my problem is solved. my question is this, would there be a problem if i run some wire directly from the battery to the button with a 30amp fuse in-line in between then from button to starter solenoid? and will it work?
Jun 17, 2008 at 9:38 PM
BMRFIXIT
  • 19,053 POSTS
Its the ignition cylinder and key
its the pass security system
you need to measure the key resistance chip and get one from radio shake
and then bypass the wiring for the system under the steering column
Jun 18, 2008 at 2:19 PM
