1992 Cadillac Deville getting no fire in distributor cap
NCHEISSER
Electrical problem
1992 Cadillac Deville V8 Wheel Drive Type unknown Automatic 219000 miles
My car is spinning over but it wont crank up. its getting fire to the distributor but its not coming out distibutor. Was told it was the computer. Replaced it and the problem is the same. Can anyone help b4 I kill my car.
Mar 17, 2008 at 1:38 AM
BUZZSAW
  • 1,198 POSTS
[quote:33fdaee26c="ncheisser"]Electrical problem
My car is spinning over but it wont crank up. its getting fire to the distributor but its not coming out distibutor. Was told it was the computer. Replaced it and the problem is the same. Can anyone help b4 I kill my car.[/quote:33fdaee26c]
did you try squriting carb cleaner down the throttle plates to see if it would start? try this first
if it doesnt, then remove the distributor, replace the pick up coil and the cam senser ( hall effect switch ). and the ign module if you havent done so. the coil is another thing, its in the top of the distributor cap. who ever told you that it was a computor is an idoit
Mar 17, 2008 at 4:53 AM
