1992 Cadillac Deville Blowing hot and cool air at the same
1992 CADILLAC DEVILLE
85,000 MILES • V8 • FWD • AUTOMATIC
BBEERAD
I have a 1992 cadillac Deville, with a 4.9 ltr v-8 engine, front wheel drive.
When I have the climate control on to the heat setting, and put it onto defrost, there is warm air blowing out the passanger side AND cool air blowing out the drivers side at the same time???
I have done the following:
Flushed the heater core 2x
replaced the thermostat
replaced the "t" restrictor vavle
checked the air delivery door behind the glove box
I do have an f48 code which means to service the air condtioning. Will that effect the heat?
what next??
Oct 27, 2010 at 9:30 AM
FACTORYJACK
  • 4,159 POSTS
F48 would probably disable the A/C compressor, and therefore not be affecting the air. Was the system low on coolant prior, or did this happen after draining it. The 4.X series of engines do capture air when the system is drained, usually up behind the thermostat since it sits highest of all in the cooling system. It sounds like you are getting warm water flowing through the core, and the reason the drivers side is cool, is because it is furthest away from the core. Are the hoses hot, at the core inlet/outlet, as well as the radiator hoses? If everything is hot, and you are sure coolant is flowing, would suspect a clogged heater core. Especially, if the compressor is not coming on.
Oct 27, 2010 at 1:46 PM
BBEERAD
I have flushed the heater core 2x.. I guess i need to do it again?? is there an efective way to flush the sysytem for this model and year of caddy?
thanks
Brad.
Oct 28, 2010 at 6:45 AM
FACTORYJACK
  • 4,159 POSTS
What lead you to that conclusion? Are both heater hoses at the core cool indicating no/little flow through it? About the only way I know to flush it is to connect a water hose to one end, and open the other end to drain. Reverse if necessary. You can also check the flow at this point. The way the core sits in the box, the lines are at the upper end, and it stands vertical, so any debris will be stuck at the lowest point.
Oct 28, 2010 at 2:56 PM
