1992 Cadillac Deville
1992 CADILLAC DEVILLE
181,205 MILES • V8 • 2WD • AUTOMATIC
BOSTON617
HOW DO I REMOVE MY A/C COMPRESSOR TO INSTALL A A/C BYPASS PULLEY
Sep 7, 2010 at 3:40 PM
FACTORYJACK
  • CAR REPAIR CONTRIBUTOR
  • 4,159 POSTS
I am not certain that you can, since all models of cadillac came standard with A/C. If it was a vehicle that A/C was an option, you have a possibility. If you can determine that a routing could be accomplished without interference, you could route a string in that configuration and take a measurement end to end. This may give you an approximate size(length) of the belt, and with a belt specification guide(usally part of a parts supplier catalog), you maybe able to find a solution through trial and error. Factoring in an idler pulley would take the work of a machinist, and most likely be expensive.
Sep 8, 2010 at 11:00 PM
