1991 Cadillac Deville where is the coolant drain
VANA
Engine Cooling problem
1991 Cadillac Deville V8 Front Wheel Drive Automatic
I want to change the coolant and only find two block plugs. Is this where it's at? Or what is the usual proceedure for draining and changing coolant in these cars?
May 16, 2008 at 6:27 AM
BUZZSAW
  • 1,198 POSTS
[quote:e86f590011="VanA"]Engine Cooling problem
I want to change the coolant and only find two block plugs. Is this where it's at? Or what is the usual proceedure for draining and changing coolant in these cars?[/quote:e86f590011]
the radiator pep cock is on the drivers side of the radiator up on the side,
I would go and have it power flushed, it removes all coolant and some good additives are added
May 17, 2008 at 1:56 PM
