1991 Cadillac Deville Received post from rasmataz
WHITECAD
Transmission problem
1991 Cadillac Deville Two Wheel Drive
You gave me information to clearing PCM Trouble Codes. My question is more along the lines of what do I need to do to repair car before clearing codes.
I need to repair the problem which I 1st wrote you before codes should be cleared. Right? When I put car in D there isn't any power, drop down to 1 or 2 everything is ok put in D after I have gained speed. Then when I stop and restart in D no power. Why is that? Does either of these codes have anything to do with that?
Thank you
Jul 21, 2010 at 3:30 PM
  • 75,988 POSTS
It's 39 TCC fault : Sounds like you have a tranny problem involving TCC which is the ( Torque Converter Clutch ) bring it in and get it pressure tested to find out more.
Be advised stay in one post we'll get to you
Jul 21, 2010 at 3:38 PM
WHITECAD
[quote:29efee94c8="rasmataz"]It's 39 TCC fault : Sounds like you have a tranny problem involving TCC which is the ( Torque Converter Clutch ) bring it in and get it pressure tested to find out more.
Be advised stay in one post we'll get to you[/quote:29efee94c8]
Sorry I'll do that from now on.
Thank you
Jul 21, 2010 at 3:49 PM
