1991 Cadillac Deville how to fix
10,000 MILES • V8 • FWD • AUTOMATIC
GRENCH
i have a 91 cadillac deville 4.9 v8 an i am geting a code e27 open thottle circiut egr im trying to find out what needs to b replaced to fix also when i turn off the car the gas pedal moves up an down for about 10 sec could that be why it does that or is that a different problam?
Dec 27, 2007 at 5:44 PM
BUZZSAW
  • 1,198 POSTS
[quote:674014a41b="grench"]Electrical problem
1991 Cadillac Deville V8 Front Wheel Drive Automatic 10000 miles
i have a 91 cadillac deville 4.9 v8 an i am geting a code e27 open thottle circiut egr im trying to find out what needs to b replaced to fix also when i turn off the car the gas pedal moves up an down for about 10 sec could that be why it does that or is that a different problam?[/quote:674014a41b]
look down the throttle plates,,, with plates open engine off, there are 2 egr tubes that may be clogged up with carbon, the plates need cleaned, and the TPS needs set up, and an IDLE relearn, the gas petal is a normal condition, the ISC motor does this to raise the idle for starting and when the ac is on, it works off the TPS signal
Dec 28, 2007 at 6:30 AM
