1990 Cadillac Deville key
50,954 MILES • V8 • 2WD • AUTOMATIC
KEVDUDE30
My key is stuck in the ignition and i dont know what to do i am 13 and i got this car from my dad who past away not to long ago and the key is stuck and i dont have eny money to take it somewhere to get it fix so if theres a way to fix it plz tell me.
Aug 31, 2009 at 11:01 AM
FACTORYJACK
  • 4,159 POSTS
Does the cylinder rotate, car start, and function normal? Just the key won't come out? The cylinder is serviced by replacement only, if it don't rotate, that will complicate matters.
Aug 31, 2009 at 3:08 PM
KEVDUDE30
i got to take the battery cable off to make sure it dosnt stay on all night and day it turns to start but it dosnt come down to turn the electrical stuff off and the key is stuck.
Aug 31, 2009 at 3:50 PM
FACTORYJACK
  • 4,159 POSTS
If it doesn't rotate back to the off/lock position, the key will not come out. You could have something going on inside the steering column, like a broken rack gear or something in the mechanism. Is the column abnormally loose at the tilt pivot, can you get movement by shaking the wheel up/down-side to side?
Sep 1, 2009 at 3:24 PM
KEVDUDE30
it dosnt move atall. i can turn the wheel and stuff. the key dosnt go down to the lock position. and how much do you think it would cost to get it fixed?
Sep 2, 2009 at 9:16 AM
FACTORYJACK
  • 4,159 POSTS
I don't know what to expect for a cost. It will need some teardown just to diagnose it, and you won't know parts needed until the fault is found. I usually bid an ignition cylinder for approximately 2.5 hours, and that may put you in the area close to identifying the problem. Parts availability may be a concern on a 19 year old vehicle. If I had to guess, it could be in the 500 dollar range, but that is a guess.If you get an idea just to put a complete used column in it, which is a cut and dried possibility, be aware that the theft code may not match, and it won't start.
Sep 2, 2009 at 2:28 PM
