1990 Cadillac Deville FRONT TURN SIGNAL BULB CHANGE
WJCNRW
Electrical problem
1990 Cadillac Deville V8 Two Wheel Drive Automatic
HOW DO YOU CHANGE A FRONT TURN SIGNAL BULB ?
Mar 9, 2010 at 9:41 AM
BLUELIGHTNIN6
  • 16,542 POSTS
1.Disconnect the lamp monitor fiber optic cable. 2.Remove the retaining nut, then pry the inner release tab upward, and push the assembly forward. 3.Remove the bulb and socket from the lamp assembly. 4.If replacing the bulb, remove the bulb from the socket.
https://images.2carpros.com/forum/automotive_pictures/261618_0900c1528025eec7_1.jpg
To install: 5.Installation is the reverse of the removal procedure. Tighten the nut to 13 inch lbs. (1.5 Nm).
Mar 9, 2010 at 9:44 AM
