1990 Cadillac Deville Automatic Parking Brake does not rele
LIZELLIE1
Brakes problem
1990 Cadillac Deville V8 Front Wheel Drive Automatic
I can not release the parking beake automatically. I have to release it manually by releasing the lever. Can you tell me why it does not release when I take the car out of park. I have allready replaced the brake release switch and it still does not work. Please help!!
Thank You
Apr 10, 2010 at 2:23 PM
FACTORYJACK
  • 4,159 POSTS
Are you talking about the brake release switch on the column? There is a vacuum actuator on the park brake pedal assembly, verify it is getting a vacuum signal when the shift lever is moved from park. If it is, replace the vacuum actuator.
Apr 10, 2010 at 6:05 PM
