1990 Cadillac Deville acceleration
98,000 MILES • V8 • FWD • AUTOMATIC
RHEANNE82802.
I had a acceleration issue. I tuned it up an no luck. I've recently took it to the shop. They put a fuel pump an spark plugs charged me $252 and give it back to me and said they didn't know what the problem was. If you give it gas it sounds like its getting air but won't speed up. What could be causing this? Thanks, Mike Fuchs
Dec 11, 2009 at 10:58 AM
FACTORYJACK
  • 4,159 POSTS
Have the exhaust backpressure checked, disconnect the exhaust before the cat, or remove the O2 sensor and drive to see if it improves. If it does, replace the cat.
Dec 11, 2009 at 3:30 PM
