1989 Cadillac Deville elc
131,000 MILES • V8 • FWD • AUTOMATIC
GARYMOSCINSKI
the trim is not working correctly, right rear is 1/2" lower the left rear, compresor runins, but can not check if maintaining 95#, relay appears to be ok, but question junction block in rear, what can be done to solve this issue
Nov 29, 2008 at 2:06 AM
  • 110,248 POSTS
Hi:
Either there is a problem with the air shock itself, or a sensor isn't working properly. You will need to have this type of problem checked by a mechanic. You will end up replacing good parts if you are not sure what it is.
Dec 2, 2008 at 9:37 AM
